The right cams
07-20-2006, 02:02 AM
The right cams
I am getting my heads back from the machine shop on friday and I am going to be doing the P.I. swap just wondering what cams I should buy. thinking comp cams xe265h
07-20-2006, 11:49 AM
RE: The right cams
Unless Your internals are forged dont go anything higher than stage 1. stage 2 and 3 make thier power higher up in the RPM range where your stock internals cant go without exploding, also you are required to get stiffer valve springs with the stage 2 and 3
07-20-2006, 12:07 PM
RE: The right cams
check out the vt stage ones from vtengines.com.
the comp cams xe265h, would be a nice came also. might could go with a comp cams xe268h
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
