Front 18 x 10 Tire size PIX
RE: Front 18 x 10 Tire size
Based on your picture with the tape measure, that's a 9" wide wheel. You measure from inside bead to inside bead.
I've never seen anyone squeeze a 10" rim on the front - without serious mods.
The best/most common size for 18x9 fronts on a 99-04 is 265/35/18. Most run 295/35/18 on the 18x10 REARs.
Like this:
Like this:
ORIGINAL: S281SC
Like this:
Like this:
you dont measure the inside of your rim well, just like the illustration shows you measure from beadseat to beadseat( where the tire seats). this is on the OUTSIDE of the wheel.
OK I have a Noob remark... I Have an 02 GT with the stock 17" Bullitt rims. I am however purchasing a set of Saleen or "S" style rims. I am getting 18x9 up front and 18x10 in the rear. I have gathered that the best setup for these rims are as follows:
265/35-18 - front
285/35/18 - rear
That is 25.3" Diameter on the front and 25.9" on the rear. I BELIEVE the stock tires run at 25.7". Will this cause real issues with the speedo? I am not concerned about gas mileage and such... just the coppers... hehehe thanks
265/35-18 - front
285/35/18 - rear
ORIGINAL: CalculatedKaos
265/35-18 - front
285/35/18 - rear
265/35-18 - front
285/35/18 - rear
ORIGINAL: Fryguy22
yea it'll mess the speedo up but not by too much
265/35-18 - front
285/35/18 - rear
265/35-18 - front
285/35/18 - rear
Will it make it read faster or slower?
ORIGINAL: Fryguy22
265/35-18 - front
285/35/18 - rear
265/35-18 - front
285/35/18 - rear
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
