mgw install help
mgw install help
Hi im attepting to install my mgw shifter in my car but I cant get the shifter removed from the tranny. I dont want to break something buy trying to get it out. Any help would be greatly appreciated
RE: mgw install help
What do you mean you cant your shifter out of the tranny? There are 2 bolts that hold the handle to the nub on the trans, then there should be 4 bolts that hold the top plate and the shifter nub to the trans. The plate with 4 bolts usually has a gasket or is held down with gasket sealer/maker, so itll take a little bit of force to get it to break free from the trans.
-P.
-P.
Thats what I was typing about. I im in fear of pulling to hard and breaking the damn thing I am new at this kind of stuff. In the instructions it says to work the shifter left to right but I am scared im going to F**k it up.
I did this mod a while ago so I'm not too sure but dont the instructions tell you to put the shift handle back on to make pulling it off easier? If you've done everything in the instructions, which are well written, it could just be the gasket sealer. Go outside right now and pull!!!
It looks to be the lobes of a twin screw. I found it on another forum and liked it since I plan on getting a KB next year.
http://auto.howstuffworks.com/supercharger4.htm This shows how it's oriented in a supercharger like eaton or kb.
not sure which one it's from though
How's that shifter coming cottonseed?
its just sticking. move it left to right...and it helps to have the stock handle reattached to give you more leverage in going left to right. you just have to unstick the sticky gasket stuff and it takes a little while and a bunch of back and forth motion to get it done. patience my friend, patience.
