Professional Products Typhoon intake....what happened?
RE: Professional Products Typhoon intake....what happened?
yeah fixed the leak just had to torque the bolts down alittle more and im dropping fuel pressure around 5000 rpms. we narrowed it down to not being the fuel pump since its only using half of its potentialand and not the injectors and we spent all day on the dyno and cant figure out why its dropping. ill keep ya posted and if anyone has any ideas on why its doing this let me know..inj arent it and fuel pumps not it so what other things could it be.
Sorry, no idea about the drop in fuel pressure. I noticed the procharger at 17 lbs in your sig. Are you tuning it with the sc? did you happen to get it all sorted out and tuned before the sc? Im curious what kind of nubers it puts down n/a. thanks
I've read somewhere before about the fuel lines fowling up somehow and messing with the pressure. Are you using the stock lines or have you replaced them?
What about your stock fuel pressure regulator?? Have you been able to swap in a good Adjustable??
Do you KNOW that the voltage going to your pump is constant?? What about minor leaks that can be exacerbated by higher RPMs??
I'm eager to find out how well this specific intake works for a few reasons....
JT
JT
KingRando
10-02-2015 08:06 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
