i got my kit off ebay... you also want to look into a gauge for bottle pressure, some colder spark plugs like the NGK TR6's, bottle warmer. that should be about it...
No you wont be ok with a 100 shot on a stock car. First off, let me try and persuade you to get the ZEX kit instead. It works on a WOT and only over 2k rpm's with the cool command module that comes with the kit. Its such a safe kit. First, you will need to get atleast 1 step colder plugs and secpnd, a chip as well. You will need two tunes, one for nos and one for when your not using nos. You MUST retard the timing by 2 degrees for every 50 shot.
I am not sure with your year stang. On my 98 I am using a NOS dry kit. I have been running 100 shot. I have used a 1 step colder plug and have not had anything go wrong with the car. I know they dont have a dry kit for 99 and up but if you use the NOS like they tell you to do in the instructions then you wont have to worry.
