just bought predator tuner.....
really can't tell a big difference.. but i installed tune.. then went back and changed parameters.. turn off o2 in back... now will that reset tune i installed? do i need to go back and reinstall tune????
again i did have my wife and kid in the car ...... which we never ride all together in the stang.....which could be why i didnt feel a bigger difference... 200 lbs
RE: just bought predator tuner.....
It isn't a huge seat of the pants difference anyway, I use the factory hp tune and just set all the parameters myself, if you are running 93 then max out the timing and you will notice a difference, I run it at 4% over stock and I can still run 87 with a little more zip..... do a search to see how it does timing, it doesnt advance it in degrees like you would think, it advances it in percntage over stock, I set it at 4 in both rpm ranges and havent had a problem with 87
ORIGINAL: 99gtstang
see thats what i wanted to do i always run 93.... but does it need to be dyno tested becuase i read you can fugg your motor up and i already have 109 K
ORIGINAL: 99gtstang
thanks, will do that now... will that harm me any? this is my daily driver..
ORIGINAL: joeybutts
with your mods i would still dyno tune it...
