pcv valve
pcv valve
can someone show me a picture to where the pcv valve hose goes from the valve cover to where on the engine?thanks...i did a head swap and forgot where it went and now i have so much damn presure in the crank case
RE: pcv valve
here you go its the nipple on the right of you idle air control and it on the left of the egr valve so in between see
[IMG]local://upfiles/31026/2B6CA0013A224D0A9BFEACE28016E879.jpg[/IMG]
[IMG]local://upfiles/31026/60CDD38830914B15AAA553CAE747C7D5.jpg[/IMG]
RE: pcv valve
ok thaks man...helps a ton...im going to go throw it on...i had so much pressure in the pan i was shooting it out threw the dip stick tube...i cut it to be like a inch long when i the swap...i couldnt get the tube to go threw the damn headers...i was the only one there so i got a little creative
