cooling fans on/off
RE: cooling fans on/off
I'd personally adjust it to come on at about 10-15 degrees above your t-stat's temperature, and go back off right above the tstat temp. Not a necessary adjustment, Ford did well enough picking temperatures.
Everyone says to leave the setting way it is that i`ve talked to. My fan seems to run all of the time since I installed the tune. Not sure if it`s on while cruising at a constant speed, but its on every time i`m going to park the car or pull up to a stoplight.
Seanam
10-04-2015 10:15 AM
09-25-2015 09:06 AM
