N02 (nitrous setup)
#21
RE: N02 (nitrous setup)
ORIGINAL: Zoie_daGT
I am surprised to see that w/ 125 jets you only saw 90 hp. Have you had it tuned for the shot?
I'm not.. Regardless of tune, the rest of your supporting Mods must be "in concert," to achieve maximum efficiency/effectiveness w/ ANY Power Adder.. That's like the addage that for every PSI of boost, you should see 10hp. Although true, when your car has every other supporting modification and a solid tune, it's not always the case..
JT
#22
10 horsepower per 1psi?!?! What dumbazz came up with that. They obviously know nothing about basic chemistry. Without a power adder your car is injesting 14.7 psi or 1 bar of atmosphere. If you make 15 psi with a blower you are at roughly 2 bar of pressure, or basically, you should double the NA power. Of course, you have to minus such things as the horsepower to spin the blower, and other such inconveniences. LOL, the top fuel funny cars and dragsters are running 40 psi through their engines, are we to assume their blowers only add 400 horsepower?
#23
Hmmm.. That's a first...
I didn't know that Fluid dynamics was encompassed in Chemistry. I studied it in Physics class... Also, since when do our cars come w/ Forced Induction?? Our cars don't injest 14.7psi unless something pushes it in there...
Also, 2 Bar of pressure is 29.4psi. Or did you learn that in Art class??
JT
JT
#24
ORIGINAL: 46blueStang
is there a kit from any manufacturer that doesnt mount the bottle in the trunk, i make custom sound systems and the back of my truck has 2 12' and its fitted to my trunk so space is limited,if not ill take out the system
jwog666
12-27-2021 08:09 PM
