technical suspension question
has anyone seen this before?
http://www.miracerros.com/mustang/t_suspension.htm
does anyone have the tourqe arm & panhard bar setup with lower control arms and no uppers or quad shocks?
that sla setup is PRICEY
RE: technical suspension question
bump
i was thinking about getting the torque arm panhard bar setup from MM.
then later on coilovers with bilstein shocks from MM also and be done with the rear suspension
ORIGINAL: M1ke
does anyone ever buy big suspension mods on these boards?
I'm not much of a suspension guru myself so its out of my realm but go on stangnet in the 4.6 section and post this...Tomustang will hook you up with some info. He sleeps,eats and craps suspension.
ORIGINAL: M1ke
bump
bump
That looks like its more for road racing and most here prefer the quarter mile. There are a few on here with k members and tubular arms up front, but not very many. Several of us have replaced shocks/struts, springs, and CAs on our cars. It really helps keep the tires down, but not the same way watts do. 1/4 milers don't need that much, but road racing suspension tuning is big $$$.
i looked for a suspension section cause i thought there was one and this is what i figured id get
the watts links arent too much more than a PB but i dont think ill need that much
If you've got some money, have you looked at the Steeda 5-Link yet?? It's got the Panhard, the subframes (I think), UCA, bushings etc...
Check out the site... From what I was reading, I don't think it uses the Torque bar and the Panhard at the same time..
Problem is though, you need to ditch the rear-exit exhaust...
JT
JT
09-01-2015 08:16 PM
