Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: How to Disable Your Seat Belt Chime
Step by step instructions for do-it-yourself repairs.
How to get rid of the seatbelt chime??
#21
RE: How to get rid of the seatbelt chime??
ORIGINAL: wwmost
no it definatly works. my bell thing never comes on any more.
ORIGINAL: RiCe_KiLlEr
im pretty sure that long technique does not work. i read that before and people tried it and the guy who posted said he was messing around. but i could be wrong
#22
god, that is like cracking a safe, i hate that chime especially when i pull my car into my garage and i dont want to buckle my seat belt for 15ft, but i would like to know how did you guys figure that out, thats pretty wild
#23
Two wires coming out of the bottom of the drivers seat belt that run all the way under the seat.... just cut them. both. the beeping is their only function, you wont have any problems or warning lights or codes or anything after you cut them..... you could always reconnect them later if you changed your mind.
#25
Thanks for the info on how to get rid of that annoying seat belt warning device. I also wear my seat belts all the time, except for pulling it out of the garage to wash it and vacuum it.
#26
That was cool as ****.
At first I thought it was a joke, like "let's see how many morons I can actually get to go out and do this nonsense."
I decided to be a moron, but when it worked I was impressed.
That's just too cool. Any more dance routines that'll do stuff with my car?
#27
ORIGINAL: shadowfoxx
+1
ORIGINAL: wwmost
Did it tonight, thanks guys.
#28
it works... i turned mine off too
ORIGINAL: Tac2cul
1. Turn the ignition switch to the RUN (or ON)
position. (DO NOT START THE ENGINE.)
2. Wait until the safety belt warning light turns off.
(Approximately 1–2 minutes.)
• Steps 3–5 must be completed within 60 seconds
or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times,
ending with the safety belt unbuckled. This can be
done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the
parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times,
• After step 5 the safety belt warning light will be
turned on for three seconds.
6. Within seven seconds of the safety belt warning
light turning off, buckle then unbuckle the safety
belt.
• This will disable BeltMinder if it is currently
enabled, or enable BeltMinder if it is currently
disabled.
7. Confirmation of disabling BeltMinder is provided
by the safety belt warning light flashing four times
per second for three seconds.
8. Confirmation of enabling BeltMinder is provided
by:
• The safety belt warning light flashing four times
belt.
disabled.
by:
#29
ORIGINAL: yetihairball
Program additional key fob remotes (up to 4 total) (PATS system 1998-2004, with square 4-button remote)
You must have ALL the remotes you're going to use -- after this procedure only the remotes programmed here will work!
- Place key in ignition and turn from LOCK to OFF
- Cycle between OFF and ON 8 times within 10 seconds ending in ON position. (Don't start engine)
- Doors will LOCK then UNLOCK
- Press any button on each remote in turn. After each press the doors will LOCK/UNLOCK to confirm the the remote is programmed.
- After finishing with all the remotes, turn the ignition to OFF. Doors will LOCK/UNLOCK again to confirm programming.
treesloth
09-28-2015 07:03 AM
