Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: How to Disable Your Seat Belt Chime
Step by step instructions for do-it-yourself repairs.
How to get rid of the seatbelt chime??
Does anyone know how to get rid of the annoying seatbelt ding? yes, i know if i buckle in it will go away. i just wanted to see if anyone has figured out the wire to cut, or some other way of getting rid of it.
RE: How to get rid of the seatbelt chime??
My 97 mustang does not have that chime but my 2004 F-150 does and I looked in the owners manual and there was a combination of things it told you to do and it made it shut up without having to cut any wires.
1. Turn the ignition switch to the RUN (or ON)
position. (DO NOT START THE ENGINE.)
2. Wait until the safety belt warning light turns off.
(Approximately 1–2 minutes.)
• Steps 3–5 must be completed within 60 seconds
or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times,
ending with the safety belt unbuckled. This can be
done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the
parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times,
• After step 5 the safety belt warning light will be
turned on for three seconds.
6. Within seven seconds of the safety belt warning
light turning off, buckle then unbuckle the safety
belt.
• This will disable BeltMinder if it is currently
enabled, or enable BeltMinder if it is currently
disabled.
7. Confirmation of disabling BeltMinder is provided
by the safety belt warning light flashing four times
per second for three seconds.
8. Confirmation of enabling BeltMinder is provided
by:
• The safety belt warning light flashing four times
belt.
disabled.
by:
ORIGINAL: Tac2cul
belt.
disabled.
by:
belt.
disabled.
by:
