need help asap
need help asap
ok almost ogt my intake off but need help i cant find out how ot get this piece off its a pipe and goes down behind the engine
[IMG]local://upfiles/5919/2141E86F0BE548A9B2753236F8555F4E.jpg[/IMG]
RE: need help asap
You can use a vice grip on the egr valvae and take a wrench and lossen the nut that holds it on the pipe. You should have done it while it was on the intake it would have been easier. But it still can be done. If your going to remove the intake manifold and not just the plenum you can remove it with just removing the egr valve and not the tube connecting to the manifold.
