Tire Size Help
RE: Tire Size Help
72MACH thanks for actually showing me a pic i think that tire size looks awesome on there. nice stang. and your tire size shows a huge difference form my 245's finally my question is answered. im going with 275's...i am at a point right now where i dont know if i should get gears or tires first because with tires i can at least buy those one at a time and the gears are more pricey so im thinking the gears since im not good at saving money and i can buy the tires one at a time. plus ill probly burn the tires off when i get my gears so i should get the gears and burn the old ones off right?
RE: Tire Size Help
ORIGINAL: DROES99STANG72MACH thanks for actually showing me a pic i think that tire size looks awesome on there. nice stang. and your tire size shows a huge difference form my 245's finally my question is answered. im going with 275's...i am at a point right now where i dont know if i should get gears or tires first because with tires i can at least buy those one at a time and the gears are more pricey so im thinking the gears since im not good at saving money and i can buy the tires one at a time. plus ill probly burn the tires off when i get my gears so i should get the gears and burn the old ones off right?
Thanks for the formulas TX02GT. Mark
RE: Tire Size Help
yes that is where i am going to get my gears. and im going to upgrade the bearing kit to a master kit with all the shims for the backlash. they said to upgrade it it would only be $29 more I talked to a guy named chris. he is the only one there, if you have any questions talk to him hes a nice guy. anyways after the install and everything im looking at $800
RE: Tire Size Help
ORIGINAL: DROES99STANGyes that is where i am going to get my gears. and im going to upgrade the bearing kit to a master kit with all the shims for the backlash. they said to upgrade it it would only be $29 more I talked to a guy named chris. he is the only one there, if you have any questions talk to him hes a nice guy. anyways after the install and everything im looking at $800
PS: Practice the discipline to save as you will need it to handle larger investments than cars!
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
M3hunter
09-05-2015 03:42 PM
09-01-2015 08:16 PM
