Tire Size Help
Tire Size Help
I currently have 245/45/17 but was thinking about going to a wider tire. the size i am thinking is a 275/40/17, do you know how much of a difference the profile is from a 45 to a 40. and does anyone have a pic of the rear end with these size tires. i would like to see how they look. thanks
RE: Tire Size Help
RE: Tire Size Help
so going from a 245 to a 275 is only a hair difference? that doesnt sound right for some reason. thats like 3 sizes bigger. i wish someone could show me some rear end pics of their car with the 275's. my tires are not wide at all. i think they might even be 225. im not sure id have to go look
RE: Tire Size Help
RE: Tire Size Help
ORIGINAL: TX02GT
It will tell you the profile and width difference. The only difference is the width is a hair bit wider on the 275. Other than that everything else is the same.
Being that its only a 245 to start with, adding 30mm is pretty signficant.
RE: Tire Size Help
1.2 per tire is not what I would consider significant. The rim size for a 275 is min 9 and max 11.
ORIGINAL: 2000GT4.6
The tire difference is fairly significant. We measured it with a set of calipers when I got my 275s on the back, and with both tires you are taking about 3 inches more of rubber touching the ground.
ORIGINAL: TX02GT
2010 Blue Ball Award Recipient
RE: Tire Size Help
