Taking off Top Strut Nut HELP
RE: Taking off Top Strut Nut HELP
ORIGINAL: monkeydude3
I just did that on mine!
Bud... you'll need an impact. I tried a wrench and a screwdriver, broke a screwdriver and almost broke my hand when the screwdriver slipped out. Went to my friend's house who has a compressor (I dont' have one yet) and you just zip it right off.
And to tighten it down, just zip it back on with the impact. I have no noise or loose issues on the CC plates with mine from doing that
ooo while you have everything apart check your ball joints for play. Mine have like 1/2" of movement, it's crazy i'm doin those this weekend too
ORIGINAL: gtboy2k
I am not trying to replace the strut, just trying to install some MM caster/camber plates. So I will need a tool from sears to remove the top strut nut?
I checked out that sears tool...may work but you may end up busting up your hands and/or the tool and still get nowhere.
i put on c/c plates not too long ago with no impact.
i put a wrench on the nut then put a big screw driver in the grove then put a pipe wrench on the screw driver (two person job)
ORIGINAL: geetee03
my nuts were stubborn
ORIGINAL: geetee03
Box-end wrench and a big **** screw driver is what I used. One man job, but hey, I'm a stud.
[sm=shades.gif]
09-03-2015 07:14 PM
09-01-2015 08:16 PM
