.550 lift valve springs
Old 08-02-2006, 11:39 PM
01BlueCobraVert
01BlueCobraVert's Avatar
Default .550 lift valve springs
Does any have or know the cheapest place to get some? Also my cams are crane "pi re-grinds" w/ a .550 lift. I got them with heads on ebay so I do not know much about them. The springs are stock and I would like to buy the correct ones for them. Thanks.
01BlueCobraVert is offline
Old 08-02-2006, 11:48 PM
Aixtreme89
Aixtreme89's Avatar
Default RE: .550 lift valve springs
I got Comp valve springs from summit, there usually pretty cheap. And if you find a cheaper sprice they match it. Also if your not going to take your heads off when you are going to replace them. You are going to need this tool. http://www.shop.com/op/aprod-p404775...er?sourceid=13
Its used to compress the spring. Also your going to need an adapter for an air hose to screw into your park plug whole to compress it and keep the valve closed when your chaging the spring. The valve spring change is the most pain in the *** part of a cam swap. You are going to have to unbolt your motor on one side and jack it up to allow you to use the tool to compress the springs near the firewall.
Aixtreme89 is offline
Old 08-03-2006, 12:01 AM
01BlueCobraVert
I am having my friend port the heads right now. He called me and sugggested to me to get the springs. I am good on tools and etc. but thanks for the advice. He said summit also. Do you know exactly what spring you got? I looked and there are a bunch. I couldn't find any w/ .550?
Old 08-03-2006, 12:04 AM
Aixtreme89
Aixtreme89's Avatar
I looked on Summit I couldnt find it on the website, check the brochure. But here are the springs. I think there the only springs comp cams makes for 4.6 SOHC motors. These are them http://www.mustangtuning.com/cocasps.html
Old 08-03-2006, 12:11 AM
01BlueCobraVert
I'll have to call summit tomorrow. Thanks
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
Lethaldosage423
10-19-2015 12:12 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: .550 lift valve springs
