Best suspension set up?
I'm thinking about lowering my car soon...what's the best suspension set up for the money? I'm thinking I'll probably just put new springs on, but I have a 98 GT so would it be neccessary to go ahead and change the struts and everything? Also I've done struts and springs on my old 95 Probe, but is there anything special needed for a Stang to do it? Thanks a lot guys and gals
RE: Best suspension set up?
You want the best? Then www.griggsracing.com is the company you want.. Very expensive but you want the best. Then I would recomend www.maximummotorsports.com second. And then www.Kennybrownperformance.com third.
Get this set up for your mustang and your car will handle like a different car. http://www.griggsracing.com/gr40worldsla.html
What do you think about this set up:
http://www.jegs.com/webapp/wcs/store...tegoryId=11233
That kit will not make you happy.. 1" drop is not worth the time it takes to do the job. IMO......If you want cheap with a good look just go with the pro kit...if you want it really lowered go with the sportlines
The best looking and the best suspension are not the same. In most cases lowering your car will make your car harder to launch. The weight can not transfer as much and the energy has to go somewhere hence the tires will break loose easier.
Matt's 95 Stang
10-05-2015 07:16 AM
