Shift Kit Heat...
Shift Kit Heat...
I'm getting a shift kit for my car soon. Will this cause my transmission to get even hotter, compared to a stock tranny, when driving or at the drag strip? I was wondering this to see if I need a transmission cooler before long, or if I can wait.
RE: Shift Kit Heat...
You're crazy!! Why would you risk it?? I was able to pick up a generic Tranny cooler for like $40, which works great..
A shift kit will MOST CERTAINLY raise the operating temps of your tranny, ESPECIALLY If you're gunning it a lot.. Besides, even if the shift-kit is mild, it's still great insurance for the life of the tranny...
Don't skimp, it's your investment!!
JT
JT
ORIGINAL: GodAmGT00
JT
JT
Just the opposite is true. The shift kit causes less slippage during shifts, which reduces the amount of heat generated. If you are installing a higher-stall converter, then THAT will increase the heat and you should most certainly install an aftermarket cooler. So, to answer the original question, NO a shift kit will NOT make your trans run hotter.
I was under the impression that since the tranny sees a TON more pressure from the shift kit, along w/ the additional driveline shock, then it would be run a little hotter, along w/ the fact that tranny is now staying in gear longer (if you have an automatic-shift valve body)..
Personally, I'd still throw one in there.. It's not hard to install, and they're not expensive..
JT
JT
I might as well get a oil cooler just to be safe. I've seen they are measured in GVW's. I'm not sure what that is. Ebay has a 18,000 GVW cooler for $46 and a 28,000 GVW for $70. My car only sees the strip a few times a year. Will the 18,000 GVW do (if anyone even knows what that is).
