What Should i set my spark advance to?
RE: What Should i set my spark advantage to?
Most people advance it all the way to 10 in both rpm ranges, you have to run high octane as well if it starts to detonate which you will know and prolly wont happen as long as you run the right octane slowly back off the timing in each incrument. Most people say they notice a difference but its hard to tell for me.
ORIGINAL: 03sonicgt
Advance it to 10?? I'm pretty sure the stock timing is 10 degrees. I think maxed out timing is 14 degrees.
your probably right I havent adjusted it in a while thanks for catching it I know that the predator is set to 0 before you bump it all the way to the right
Golfsito
10-06-2015 11:02 AM
