my engine, what to do
Well I've done a lot of talking to people, and since I have an o/r H now I can really monitor my oil burning situation. It seems the way my car is smoking would point directly to the valve guide seals/top end. So how bad would it be to hold me over for my horsepower thirst, to do a PI swap with stage 1 cams? I figure this would be an inexpensive option to get some good horse out of my engine for a better dollar than a full rebuild right now, AND the whole engine doesn't have to come out of the car for this one either. I figure if I get a beater car this year, I may be able to pull off doing the swap over winter/early next spring.
It still screams and has good compression, which is why I figured the bottom end has to be still pretty good. Any input, let me know
George
George
RE: my engine, what to do
Compression test hmmmmhmhmhmhmhhm?
How do you know the bottom end is good with all that smoke.
If it is the heads, now is the time to do the PI swap. Just do it right with the intake and cams as well.
well, with the smoke... it smokes at startup. It smokes after idling or sitting off. Buncha mechanics I talk to say it sounds like valve guide seals. If I hit it, rip on it... no smoke. Only after idling or sitting off.
I checked the compression a lil while back, and it's at about 150 psi or so per cylinder...
It's not smoking more than before. There are no more cats, so the smoke is now visible lol
I just figure I'll do one more final compression test to be sure, and then it'd be a good option to do an intake, heads, stage 1 cams and some headers and i'll be in the 250+ rwhp zone and be set for a while
ORIGINAL: monkeydude3
yup! As much as I want a full engine right now, it's not feasible. A pi swap, however, is!!!
What would one cost me in parts roughly with me doing pretty much all the work mahself?
would it be possible to install thicker head gaskets to keep the compression ratio tame?
Yes you can install a thicker head gasket to bring your compression ratio back down, but in reality, I think you only are going to pick up about half a point of compression.
all right sweet. Sometime in the near future I'm gonna do another compression test to make sure everything is still good, then if so I'm gonna start piecing together a PI swap
one could only hope this kit will be around in the future...
http://cgi.ebay.com/ebaymotors/1996-...spagenameZWD1V
George,
Sounds good, but I'd just keep an eye on those for now. You're bound to run into someone along the lines who will have some cheaper stuff.. I know you keep this in mind, but what about the Cams too??
Also, the good news is, there's always people out there looking for OEM replacement stuff.. Your old heads serve as a great core-charge, or platform to rebuild, provided it's just the valve guides. I'm thinking, since performance hasn't suffered, they're fine...
JT
JT
