Painting calipers
RE: Painting calipers
The factory painted Cobra and Bullitt calipers are actually powder coated, not painted. Prep the surface right, but I wouldn't use a primer. Most, if not all, primers will not hold up to the heat generated from the brakes. If you apply a high-temp paint over low temp primer, the high temp will still bubble, peel and flake off. Just use a good high temp paint like RustOleum high temperature or equivalent. I think it is good for up to 800 deg.
I was kind of debating the same thing. I did a quick PS of my car, the 2nd one is how the 10th anniversary Cobra calipers were paitned, and I think thats how I'm going to do mine because it looks more even. Either way I'm not doin the holder in the front, IMO that is too much... I also suggest Caliper Paint by VHT.
[IMG]local://upfiles/25112/F2172313DD634AB686DF7BF5162F4DEA.jpg[/IMG]
[IMG]local://upfiles/25112/CA467E7DD81943D1BA90E9E94C2ECE2A.jpg[/IMG]
