couple of basic questions
RE: couple of basic questions
Gears in the tranny and rear end multiply the torque produced by the engine. Your engine produces a torque curve that changes with RPM. For reference, HP=(RPM*torque)/5252. If your engine produces 100 lb-ft of torque at 1000 rpm, and your run that through a 10:1 gear set, you'll have 1000 lb-ft of torque at 100 rpm (assuming no losses, of course). Notice how the horsepower is the same. However, you will accelerate much quicker with that 10:1 gear set than you will with the 1:1.
Now, if you change gear ratios, your end speed will be constant and your engine speed will change, moving you along the torque curve. If you're at 100 lb-ft of torque at 1000 engine rpm through a 10:1 gear and change to a 5:1 gear, your output will still be 100 rpm, but your engine is now at 500 rpm, where it produces, say, 50 lb-ft of torque. Through the gear multiplication, you're now putting 250 lb-ft of torque to the ground with your 5:1 gear ratio, making acceleration more difficult.
That help?
Much faster than any legal speed limit you'll find in the US.
That help?
ORIGINAL: Eightiesrock1980
Just wondering what is the highest speed you can go and still down shift to 4th (like say im on the expressway) with it still being safe. i got a 2002 ford gt mustang convertable (completelystock)
http://www.tchracing.com/tech/gearca...selectedgear=4
stock tires + 3.27 in 4th = 5703.2 rpm @ 120 mph
so pretty much any time you want or need to
