99 Continental 32v in a 96 Stang GT?
Old 08-07-2006, 05:23 PM
tron2003
tron2003's Avatar
Default RE: 99 Continental 32v in a 96 Stang GT?
So what's the difference between the 4V DOHC 98 Mark VIII motor and the 4V DOHC Stangs?
tron2003 is offline
Old 08-07-2006, 05:25 PM
GodAmGT00
GodAmGT00's Avatar
Doh!! I apologize, I was thinking Town-car, in which case, it's almost a direct swap...
I don't think there's any difference between the Mark VIII's/4v 4.6's, like I said before, less the Flexplate/flywheel..
JT
GodAmGT00 is offline
Old 08-07-2006, 05:48 PM
droptoppony
droptoppony's Avatar
ORIGINAL: amoosenamedhank
The continentals are FWD cars and they use a frFWD block with a different bell housing pattern. That block will not bolt up to a RWD transmission so it will not work in your mustang. You can use the heads but for that hassel I would just sell the car.
you are correct sir...block is worthless to us.
droptoppony is offline
Old 08-07-2006, 08:23 PM
phil_gou
phil_gou's Avatar
ORIGINAL: tron2003
The Mark's internals are weaker and the intake manifold is also not as good as the cobra's. The cobra's crank uses 8 bolts to connect to the flywheel and the marks use 6.
phil_gou is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Roxon68
03-17-2016 08:13 PM
Bokeo
10-10-2015 08:28 PM
sjforcup19
09-15-2015 09:58 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: 99 Continental 32v in a 96 Stang GT?
