wet vs. dry shot
RE: wet vs. dry shot
read here:
http://members.aol.com/agspeed/nos.htm
lol, nevermind, it doesn't explain it.
wet shot provides it's own extra fuel (you tap into the fuel system).
dry shot depends on the car's fuel system to get fuel.
I've heard wet shots are better for higher jetting numbers. I believe you shouldn't go over a 100 shot with a dry kit. I also heard wet kits are safer and better when going 125 or higher.
Dry: good for 75 to 100 shot
Pros: easy install, cheaper
Cons: danger of lean conditions
WET: good for 100-150 shot more on built engine
Pros: higher horsepower, better protection against lean conditions
Cons: danger of pooling fuel in the manifold and blowing the manifold if a backfire happens, more $$$
Direct port: good for 100-150 shot (stock engine) 300 on built engine
Pros: good power gains, no fuel pooling
Cons: cost, install is more difficult, did i say cost
I would suggest a wet kit, but every nitrous guy is different. The only real danger I will have with my set up is the puddling in my intake. With a wet kit, you have the danger of blowing your intake through your hood, with a dry kit, you have a bigger chance of blowing your motor. But when done right, any nitrous set up will work right with the right safety precautions.
which wet kit do you guys recomend because im trying to get some spray but i dont know if there is a difference between brands or what,
is NOS as good as nitrous express, or venom, or etc,etc
i am sure this is going to be a very argumentative question, but which would be better in your guys opinoins.... spray or s/c, i know they are alot diff, but just seeing some of yalls thoughts...
