Eibach Sportline, 2" drop...
RE: Eibach Sportline, 2" drop...
man i lowered mine 2" and i never got the cc plates. Big mistake. I ate the **** out of a good set of high performance tires. It wears on the insides of them too hard and now theyre almost down to the core. Time for new tires and cc plates!
ORIGINAL: ben790450
+1
luckily the tires I fu**ed up were already old and due for replacement
+1 for Maximum motorsports C/C plates, they're by far the best out there. You're gonna need a bumb-stop kit so you dont bottom out when you go over large bumps. Also, u'll need an alignment as soon as you finish lowering it.
bumpsteer, not bumpstop. Bumpsteer is for the tie rod ends I believe. You can use them with C&C plates or not. It would give you more versitility in adjusting your front end, but unless you road race, you don't "need" them. My drop was only about an inch and I used offset rack bushings, but 1.5 and over need more than that.
Good luck.
Good luck.
