Window problem
Window problem
My passenger window will not roll up all of the sudden. I just rolled it down a little bit ago. Now, it will go up about a half an inch and stop. When rolling it all of the way down, there is a "Clanking" metal on metal noise. It sounds to me like a lose rod or something inside.
I am now trying to get the door panel off...is there anything but plastic clips holding the thing on? It feels very solid, but I can't find any screws or bolts that could be holding it. I did remove the bazels around the window controls and the trim inside the door handle, but can't find anything else.
I just want to be sure before I pull too hard on the panel and break it while it is being held in by something of more substance than a plastic clip.
RE: Window problem
The time I get off most shops are closing[&o] Maybe tomorrow[&o][:@][&:]
ORIGINAL: TX02GT
Did yours ever get fixed?
ORIGINAL: blueherd02gt
you unscrew the two screws buy the door handle and lift and pull I spent my weekend to no avail going through the same thing
RE: Window problem
ORIGINAL: TX02GT
EDIT: Ohhh, so this is current events. I see. [:@]
RE: Window problem
Naw the panel came off easy (remember to lift and pull out) my window motor locked up and I tried to replace it myself but I kept cutting the **** out of my arm and hand. So I called a guy (referred by a buddy) and he said it can be replaced with the window in but it is a real PITA. So when I get a chance I'll shoot by his shop (he doesnt do mobile visits) and pay him $40 to do it. I bought the window motor from orieley"s auto parts for like $49 with core
RE: Window problem
Well, the only thing I was doing wrong with the panel was pulling out instead of up. Got it off no problem now. I can't tell whats wrong though, it seems to me like the rails are getting in a bind.
The other day I closed that door and heard a rattle, I think something came loose then and I just now rolled the window down. It looks like I am headed to the shop. [:@]
I hope this isn't going to be the theme of my Mustang ownership...
RE: Window problem
It is a pain to get the motor off but honestly I should have paid somebody in the first place. My drivers side door now needs retinting[:@]
-P.
