I want some REAL sticky tires
RE: I want some REAL sticky tires
Saleen wheels are identical to EAGLE model 077's which may actually be the wheels Saleen uses as like I said they are exact except the Saleens are stamped "saleen" True Saleemns are $400. each. I got a set of Eagle o77's for $750. shipped with lugs, locks and stems. Mine were all 8" wide so not sure about the other widths. try www.jdwheels.com Mark
PS: SORRY, They are listed under FWD and only nuop to 8" wide.
Ive got the 555's, and believe u me they will hook up just fine. Ive tried to get loose with them and it just doesnt work. I tried messin around even in the rain one day and they hung on pretty well. You cant go wrong with Nitto's.
ORIGINAL: 03GTGreen
ORIGINAL: mylongvictor
How wide are your rear tires?
ORIGINAL: 03GTGreen
ORIGINAL: MustangMan528
so i will be able to fit 315's onto an 18x10 rim?? Won't that be pushing it??? The place that sells the rims recommends a 285.
"recommend" means that is the smallest tire wou can put on the rim, in a 18-17x10 rim you can fit a 335's if you want , of course is going to be more expensive, go with 315's you wont regret it
ORIGINAL: 03GTGreen
There 245/40/18's all the way around. I was gonna get 275's in the back but I want to be able to rotate tires.
ORIGINAL: 03GTGreen
can't rotate them... thats the only thing it sucks about having 315 in the rear... why didn't you get 275's all around???
i heard the best "sticy" tires are nittos, hossier and mickey thompson's, i have gooyear eagles f1' in my rears and the hook up just fine
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
KingRando
10-02-2015 08:06 AM
