Backpressure, torque and YOU!
All over internet car forums people seem to think that when they add bigger exhaust pipes they loose torque because of the loss of backpressure. This is simply not the case. I've decided to contribute a little and post some articles that help explain the differences between exhaust backpressure and exhaust velocity and how they relate to torque and that seat of the pants feeling of lost power.
This was taken from ProficientPerformance.com
This little tid-bit is from howstuffworks.com
I have bolded the important parts for those who don't like to read a bunch of dribble.
Now, the next time someone asks why they lost power after adding a new exhuast piece, you can tell them it's because of lost exhuast velocity and NOT backpressure. Backpressure is never good.
Most of the time bigger is better, but that's not always the case with exhaust. Today's late model cars are designed with several restrictions on the manufacturers. So in order to perform but still stay within the limits of emissions and other regulations, the exhaust is usually the first thing to suffer from the factory. The easy power that is found in changing the original equipment exhaust system, is just one of the many reasons there are so many aftermarket manufacturers capitalizing on this insufficiency. But just opening the exhaust doesn't always make more power, it takes the correct combination of flow capability and velocity. That's why performance exhaust manufacturers spend so much time in search of just the right combination, so that they can ensure peak power to their customers.
In this article we will discuss the effects that exhaust backpressure has on your engine. Backpressure is the restriction of the exhaust gases that are produced by your engine while they are being released through your exhaust system. Exhaust gasses are the burned and unburned gasses that are released out of the exhaust system after engine combustion happens.
The exhaust system should have minimal restriction to the exhaust flow that is being released in order to create the most amount of power from the engine. With restriction present, backpressure is developed, making the engine work much harder to release the exhaust out of the engine cylinders.
The standard for exhaust diameter is to not run too large of exhaust, for the engine needs a certain amount of backpressure. This is correct in the sense of one should not run too large of diameter exhaust tubing, but the statement of the engine needing backpressure is not. You need to have the least amount of backpressure possible to produce maximum power. Too large of diameter exhaust will cause a power loss and loss of low end torque because a larger pipe has less exhaust stream velocity than a smaller pipe. If the exhaust pipe is too large, then the exhaust flow will be slowed with less velocity. There are exceptions, forced induction or high-volume race engines require a larger diameter exhaust due to the flow characteristics of the engine. Supercharged and turbocharged vehicles can have an exhaust gas volume of 1 to 2 times more than an equivalent displacement naturally aspirated engine. In this case, one is able to use a larger diameter of exhaust for greater performance.
Headers are one of the easiest bolt-on accessories you can use to improve an engine's performance. The goal of headers is to make it easier for the engine to push exhaust gases out of the cylinders.
When you look at the four-stroke cycle in How Car Engines Work, you can see that the engine produces all of its power during the power stroke. The gasoline in the cylinder burns and expands during this stroke, generating power. The other three strokes are necessary evils required to make the power stroke possible. If these three strokes consume power, they are a drain on the engine.
During the exhaust stroke, a good way for an engine to lose power is through back pressure. The exhaust valve opens at the beginning of the exhaust stroke, and then the piston pushes the exhaust gases out of the cylinder. If there is any amount of resistance that the piston has to push against to force the exhaust gases out, power is wasted. Using two exhaust valves rather than one improves the flow by making the hole that the exhaust gases travel through larger.
In a normal engine, once the exhaust gases exit the cylinder they end up in the exhaust manifold. In a four-cylinder or eight-cylinder engine, there are four cylinders using the same manifold. From the manifold, the exhaust gases flow into one pipe toward the catalytic converter and the muffler. It turns out that the manifold can be an important source of back pressure because exhaust gases from one cylinder build up pressure in the manifold that affects the next cylinder that uses the manifold.
The idea behind an exhaust header is to eliminate the manifold's back pressure. Instead of a common manifold that all of the cylinders share, each cylinder gets its own exhaust pipe. These pipes come together in a larger pipe called the collector. The individual pipes are cut and bent so that each one is the same length as the others. By making them the same length, it guarantees that each cylinder's exhaust gases arrive in the collector spaced out equally so there is no back pressure generated by the cylinders sharing the collector.
RE: Backpressure, torque and YOU!
Nope...
As he had carefully posted about this, the 2 are often confused.. Velocity is what you need.. Back pressure prevents the exhaust from flowing correctly down the pipe... The exhaust is accelerated out of the engine during the exhaust stroke..
What he was definitely trying to get at, was that people say that you will lose power from exhaust mods because you're getting rid of back pressure. That is NOT the case.. You lose power, because you've taken away the positive exhaust velocity, necessary to evacuate all of the exhaust gases out of the combustion chamber, therefore, your engine can't fully scavenge the rest of the exhaust gases...
If you read through the article, it explains it very clearly...
BTW, good post.. Hopefully it'll clear some things up...
JT
JT
LivingInThePast
09-16-2015 12:20 PM
