11.5 compression???
RE: 11.5 compression???
Yes
Most ive ever been able to get away with is 10.0 to 10.3
You might be able to go a little higher on a carbed motor but you would have to retard your timing quite a bit for it not to ping.
10.5 might be ok too. Last 350 chevy i built had 10.7, we had to retard the timing to 8 degrees at idle so it wouldnt ping. It worked, but i know the motor had much more potential if we could have raised the timing.
We went to the track a few months later and got some race fuel, bumped the timing up to 12 degrees and cut quite a bit off his 1/4 mile times.
uberstang1
09-20-2015 06:42 PM
