More power!!
RE: More power!!
300 REARwhp can't be obtained even with all the bolt-ons available. To get it you will have to at least do a camswap. Either that or just a poweradder will do it. But if you wanna do it NA you will have to have at least a set of cams.
Now 300 at the flywheel would be pretty easy. pretty much all you need is pulleys, chip, mid-pipe, cai, and cat-back. That will put you a tad over 300 hp.
By the way, the industry standards are:
hp = flywheel horsepower
rwhp = rear wheel horsepower
frhp = front wheel horsepower
It's obviously just a misunderstanding, Im sure when referring to a mustang most people will assume by fwhp you meant flywheel, but nevertheless fwhp does infer front wheel
RE: More power!!
Let me reitterate the question. Because from what Ive seen more HP doesnt necessarily mean faster. What do I need to do to get this GT fast enough to not just totaly be embarassed by The 05 gts?
RE: More power!!
ORIGINAL: AirForce2004
2000GT4.6 you mean to tell me with all those mods you have listed you havent reached 300 hp yet? Im kinda getting depressed I bought this GT.
My car is completely different that when it was stock. I have no doubts that a stock 05 wont have anything for me.
RE: More power!!
What type of cams would I be looking for and what price range for part and install? Im a bit new to this.
mdvaldosta
Labor shouldn't be much, it depends on which route the shop takes installing them. With the new anderson cam tool I can change a set of 4.6 2v cams in an hour and a half. But, without the tool I'd have to pull the timing cover and that would add a good 2 hours to the job. So...
Labor on VT cams w/out chaning springs would run you about 3 hours labor - most shops are $70/hr so about $210.00 if their smart, if not then it's gonna be about $450.00. It takes a good 4 hours to do the valve springs by the way. The cams would cost you about $550.00 and you will need either a programmer to fix your a/f ratio or get a tune somewhere. If not your gonna have ideling problems.
A cam change is the single biggest "borderline bolt-on" hp increase you can make to your car. But.. if your not doing it yourself and your gonna have to pay for a tune as well - the cost can easily exceed $1,300.00
RE: More power!!
Hey AirForce2004, don't worry about the 05 gt. I talked to a rep at the ford dealership that had a chance to drive an 05, and he said a mildly modified 99-04 gt has nothing to worry about against a stock 05 gt. I am sure the 05's weight has something to do with the fact that its not much faster than the previous gt. Also, i searched online and i saw a couple websites that stated the 1/4 mile and 0-60 times of the 05 gt and they were exactly the same as 99-04 gts. It might have been type-os but i could beleive it.
Dude don't have buyers regret...there are tons of people that would kill for an 04 mustang gt.
