driver window wont go up
When i click the window down the motor clicks almost sounds like a starting cylinoide when it is stuck. But then when i hit it up nothiong happens is it the motor or could i try anything else besides that
_________________________________
01 mustang gt convt. 5 speed
RE: driver window wont go up
Mine does the same dam thing, but it's random... It hasn't done it in about 2 months now, but sometimes just wouldn't go down but could hear clicking. Going into dealership next week for the window motor/selenoid to be replaced along with some other random crap I may as well have done while it's there.
Edit: I doubt it will be covered under warranty for you since your 3 years is up ...
I just started experiencing the same exact problem with my '02 GT 'vert. I put the window (and top) down while I was running some errands. Parked it and tried to put the windows back up. Three of them came up, but the driver's side window didn't move. If I click the switch down, I can hear it click. But, if I click the switch up I don't get anything. I called the dealer and I'm dropping it off there tonight. Hopefully I'll have it back tomorrow. I'm sure I'll have to pay for the repair since I'm over three years (even though the car only has 32,500 miles). I'm thinking it may be a solenoid / relay? Any ideas anyone?
Jeremy
'02 GT Convertible
Jeremy
'02 GT Convertible
I encountered this exact problem. The driver side window rolls all the way down and then it won't roll back up. There is a clikcing noise when you press the switch down by the fuse panel, right? Itook the door panels off and exposed the motor terminals. I then took two long pieces of wire and ran it directly from the batter to (positive and negative) andplaced them on the motor terminals. This rolled the window back up. After doing this, the problem fixed itself. One of my mechanic buddies said sometimes power windows get stuck.
Hope this helps.
Hope this helps.
In case anyone is interested... I had my window fixed at the dealer. They had to replace the power window motor which cost about $280 all together (about $150 was the motor itself). I'm sure I could have gotten it done for less at an independent shop (I have one I love), but I needed it done quickly and the dealer was the fastest option.
Jeremy
'02 GT Convertible 5 Spd
Two graco toddler seats
Jeremy
