i have a set of rack bushings i wanna put on but i dont know where to get installation instructions for them. I bought them used w/out instructions. Anyone know of a link????
it actually pretty easy first jack the car up and get some jack stand to support it use a manul really helps alot. undo on bolt using a 13mm socket on the steering shaft seperatt the steering shaft from the rack and pinion then look in front of the rack and pinion unit should see two bolt take those two off the other end of the bolts are on the oppisite side of the k member. then pry the rack and pinion out. take the old bushing off and put new ones in and do the proscess backword fre installation. i hope this is not confusing
