CAMS
CAMS
I have a question since I do not know much about cams. I am looking to buy a set of heads with cams allready installed but I am not sure how wild the grind is. Here are the numbers that go wit it: grind 267/282, duration at .050 226/235, gross valve lift .540 could some on e please dicipher this and let me know if this a stage II or III cam. Thanks for the help.
RE: CAMS
how much rwhp would you add when you install stage 2 heads and cams? and how much would installation cost? i'm trying to decide what my next mod will be and i would like to know how much money i need to save up.
RE: CAMS
it says that it can increase hp by 65-100. what does this tranlate to rwhp? how much for installation of this kind of setup?
http://www.online-racer.com/Modular_...ular_heads.htm
RE: CAMS
i installed my cams myself they werent that bad i dont know about heads it doesnt seem like they much more worse than the cams i know at my local mustang shop they charge $950 for cam install but they remove the motor and degree them perfect
junior04
09-28-2015 10:53 AM
