fog light instalation
RE: fog light instalation
Did you get just the clear lense or entire assembly? If its just the lense then your gonna have to unbolt the entire assembly and take off the old lense and glue/silicone the new one on. I chose to just spend the extra money on a complete fog light assembly with the clears already on. Took me under 10 mins to swap rather then prying off old lenses and glueing etc...
I bought the whole assemblly, but I just replaced the lights itself. Just get a screwdriver and unscrew the (1) screw on the top of the light then use a screwdriver to wedge out the light, now the whole assembly, then wedge the new one back in on both sides, then screw back on the screw. Make sure to use the spring that it comes with, this way you can adjust the position of the light by tightening the screw or loosening.
I just installed some yellow fog lights on Saturday 08/12/06, never did it before or read anything, took my like 15 minutes.
you need to get the front end up at least a foot so you have room, then there are 3 bolts for each assembly. 2 bolts are easy to do, but one you gotta sneak around the rai guard to get to, kinda a pain when unbolting it this is for the drivers side. the passenger side is the same deal, 1 bolt is annoying to undo but no big deal. once you get both assemblies off its downhill from there.
Diode Dynamics
28
05-26-2022 12:02 PM
inyadreems
08-21-2015 09:10 AM
