You have to remember staic compression doesnt really mean much on a running motor. Thats what the compression is if the valves remain closed. But you can run on 10:1 compresson fine and have a custom cam ground for you so it will releive some of that pressure while the pistons heading up to TDC so it essentially lowers the compression ratio.
