Weird noise
RE: Weird noise
Don't look past the clutch.
Slightly push down on the clutch pedal when you hear the noise, if it increases or goes away, you most likely have a faulty throw out bearing, and if it has been squeeking all of those 27k miles and you didn't notice it, it's probably worn the clutch a little more than you want...
RE: Weird noise
ORIGINAL: Dan04COBRA
RE: Weird noise
TSB # 22334-33: Don't drive your car like an a-shole, it may break something.
Usually, unless the parts were defective from the factory, premature clutch/clutch assy wear is the result of some questionable driving techniques...
Do you do a lot of hard, hard driving?? Dumping of the clutch?? That could be where you may need to ease up.. Maybe your clutch just needs a little bit more adjustment..
JT
JT
