Where did my Power Go???
I have a 98 GT and after I installed an o/r h-pipe and flowmaster 40s, I noticed the power down low felt a lot weaker. What happened? Dont Say the flowmasters is what happened. I know a lot of people dislike them, but surely they are better than stock. With the stock exhaust, I could bark the tires shifting into third gear and now, it seems like it bearly want to bark them in second. I have 3.73 gears and I can fry the tires in first, shift to second and continue to blow them up, but just running up the rpms and shifting seems like I lost some power. Can anyone explain this to me. Thanks...
RE: Where did my Powr Go???
I'd check the system for leaks.
When you open up the exhaust, generally it will help your car breath in the higher RPM's and it'll almost give you the feeling as if it lost some power down low, which could possibly be the case but it's so minimal that unless you are Jesus you can't really tell.
Generally it's the increase of top-end that gives people the illusion that they lost all their low end grunt.
Do you have MIL's or used a tuner to shut off your CEL?
Its normal. Your freeing up more backpressure down low. Its like putting headers on. Everyone complains that they loose low end power. If you had a leak you'd hear it. Trust me! haha. Exhaust takes away your low end pressure but if gives you a lot on the top end. Thats where you need it most.
ORIGINAL: ben790450
Same happened when I put my BBK O/R X-pipe on. It felt like I couldn't chirp the tires anymore...Took a week to get use to the pipe and now I can chirp them again. It is a noticeable difference in acceleration at higher speeds (little, but noticeable).
RE: Where did my Power Go???
ORIGINAL: jcassell1
Dude, the flowmasters is what happened!
