need some info!!
Old 06-16-2004, 11:11 PM
RollinThunder
RollinThunder's Avatar
Default need some info!!
what octane should I run when I get my car dynotuned this mon??
RollinThunder is offline
Old 06-16-2004, 11:58 PM
w11988
w11988's Avatar
Default RE: need some info!!
I would say put in 91 and tell them you want the car tuned to run the higher octane. That is assuming you want to get better HP, not better mileage.
w11988 is offline
Old 06-17-2004, 12:47 AM
04mustang
04mustang's Avatar
when u get tuned they will tell you what you need to run . if they are leaning out your air fuel ratios and timming then you will prob need to at least run 91. you should be running at least 92 with the maf kit you have. i have the same thing. and C&L recomends running 92 to prevent any possable detonation.
04mustang is offline
Old 06-17-2004, 11:47 AM
RollinThunder
ORIGINAL: 04mustang
what exactly is detonation??
Old 06-17-2004, 01:38 PM
MikeHawke
Retired MF Moderator
MikeHawke's Avatar
pre-ignition of fuel/air mixture in an engine (before the spark plug lights) due to high pressure or high temperatures. Low octane fuels have more of a tendancy to detonate. Usually occurs in the combustion chamber...at least you better hope it does.
MikeHawke is offline
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
RCS02v6
09-29-2015 01:46 PM
junior04
09-28-2015 10:53 AM
GLOCKer
09-28-2015 07:36 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: need some info!!
