stupid question??
RE: stupid question??
It will work, but you need bigger injectors, prob. 30 or 42's and his MAF sensor. You will need a pulley tensioner and a belt. Not sure if the tensioner you have will work or not, but I'm pretty sure he has his tensioner bolted to his pi heads. Now don't be fooled with his PI heads. They are not the same as mustang PI heads. The combustion chamber is slightly larger and he only has 8.4:1 compression to accomodate for the bigger displacement motor and forced air. Your car will actually decrease in compression if you use lightning heads. Just as the DOHC heads do the same!! But to make the s/c work won't take much at all. You'll also need a new radiaor hose and a few other small items. If you run an underdrive pulley on the s/c you can get like 10psi out of it safely!!!
ORIGINAL: 97targa
^^Cause its just the blower, and I have yet to see an Eaton intake he could put it on for the 2V. I was gonna do the same thing with one from a Cobra. The only chance you have is if you were able to find an intake/intercooler to put it on and ur best bet would be from Saleen or Roush, but I dont even know if an eaton blower could be fitted to them cause I think they are both Whipple's. I would go with what OnyxCobra said. Grab if from him for the cheapest hes willing to give it for, and then sell it on ebay, u can make more off the deal by just the fact that its ported and able to push 17-19 pounds of boost.
It wont work a lightning is a 5.4L DOHC. You will need the entire set up, 4v heads and a 5.4L shortblock. The 5.4L shortblock is wider then the 4.6L there for you will never be able to squeese it in there. The DOHC heads have a different intake port configuration then the SOHC so the intake wont line up. He will probably use some of the stock parts to install the new one.
ORIGINAL: oxfordgt
