What size tires would be nice for these rims
RE: What size tires would be nice for these rims
ORIGINAL: coffinator6
on the 18x9 i would go with a 245/40/18 on the rears i would go with a 285/35-40/18.
the middle number is the percentage of the tires width in milimeters. so a 285/35/18 is 11.2 inches wide, and each sidewall is 3.9 inaces tall. So if you multiply the sidewall height by 2 and add the rim diameter it will give you the diameter of the tire. Now remember there is a difference between the diameter we calculated and rolling diameter. Rolling diameter is going to be slightly larger.
mike
mike
you NEED to go with 275/40/18 front and 315/35/18 in the rear, if you go the same height front back your rear tires will be shorter due to the percent width or 40 on a 275, so 40% of the width of a 275 tire will be x inches tall, the rear will be 35% of 315 wide, this will keep your tire height even all around, UNLESS, you want the rear tire height to be greater than the fron, a slight rake if you will, haha
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
10-05-2015 06:07 PM
09-03-2015 07:14 PM
09-01-2015 08:16 PM
