Lincoln 4.6 dohc swap into a 96 gt
RE: Lincoln 4.6 dohc swap into a 96 gt
Get the 96 mark 8 motor. I took apart my 94 mark 8 motor and the only difference in the wiring harness than mine is that the TPS sensor connector is different and it has knock sensors. It still only has one cam sensor, unlike what I have heard that it has two. Painless makes a wiring harness, I will call them up on monday and see how complete the wiring harness it. Then I will let you guys know.
so i will have to change some of the wiring? that would seem a little wierd, that kind of goes back to what i was saying earlier. could i just put my npi intake manifol on there. that way i could use all of the existing intake/sensors/etc.?
ORIGINAL: gary96gt
VS the SOHC see the difference?
so i can use the intake of the lincoln motor, i just have to get the wiring harness and ecu? Just clarifying becausei have decided to buy the engine i just want to make sure what im getting into
thanks for the help btw
Matt's 95 Stang
10-05-2015 07:16 AM
