Leaking exhaust system? (with vids)
Old 08-20-2006, 07:19 PM
Flyingmau5
Flyingmau5's Avatar
Default Leaking exhaust system? (with vids)
What are the different ways to tell if an exhaust system is leaking? Any visual and/or abnormal hearing aids? Do the sounds differ if there was a leak in a midpipe or a catback. I just put an o/r x pipe and it is orgasmic loud. Especially past 3k rpms. I mean so loud the whole interior shakes a lil...
Flyingmau5 is offline
Old 08-20-2006, 07:35 PM
MustangChris04
MustangChris04's Avatar
Default RE: Leaking exhaust system?
you will hear it ticking...
MustangChris04 is offline
Old 08-20-2006, 07:56 PM
code3GT
Mustang Nazi
code3GT's Avatar
or squeaking. You can look for carbon deposits on all the joints.
code3GT is offline
Old 08-20-2006, 08:26 PM
wwmost
wwmost's Avatar
i used to hear a tick noise under acceleration but then it just went away. this was after i got my full exhaust put on. to check for leaks, try to tick a rag in the exhaust pipes and let it idle for a second or tow. if there is a leak, you will hear noise or air come out of the leak.
wwmost is offline
Old 08-21-2006, 01:09 AM
Flyingmau5
Flyingmau5's Avatar
can i get it solved by welding the damn thing???
Old 08-21-2006, 01:10 AM
so1o2k3
so1o2k3's Avatar
exhaust leaks can cause detonation, which will sound like a nasty rattling/gurgling.
so1o2k3 is offline
Old 08-21-2006, 01:15 AM
Brute03
Brute03's Avatar
how does it sound exactly? because some x pipes tend to have rocks-in-a-tincan sound at certain rpms
Brute03 is offline
Old 08-21-2006, 01:19 AM
Flyingmau5
Flyingmau5's Avatar
it sounds horribly loud after 3k rpms no matter what speed I'm going. I could be driving around in the parking lot and anything higher than 3k rpms, the rattling sound is horrible. maybe i should go out and take a sound clip of this [8D]
Old 08-21-2006, 01:25 AM
Brute03
Brute03's Avatar
yea make a clip, then we'll have a better idea
Brute03 is offline
Old 08-21-2006, 01:28 AM
Flyingmau5
Flyingmau5's Avatar
good good...
i'll go do it now [8D]
Quick Reply: Leaking exhaust system? (with vids)
