Anyone know about this mod??
I heard there was a little mod you can do to help your rpm's from hanging for so long. I know it has something to adding a gasket or piece of metal with a smaller hole in it, to the IAC, i think.......I may be way off so can anyone ellaborate?
RE: Anyone know about this mod??
it looks like this:
http://cgi.ebay.com/ebaymotors/4-6-5...04497504QQrdZ1
You can also have it tuned ask your tuner about setting the dashpot.
i saw my buddy do it, he used a really thin piece of aluminum. use the iac gasket as a template and trace it onto the sheet metal (including all the holes) and cut it out. you might have to do a little trail and error to find the ideal size for the air hole so it lets in just enough air but not too much
I have done it and have had it on my car 2 yrs and it helps noticably I just went to homedepot and picked up a copper pipe end and drilled whole in the middle I forget what size ill have to double check about the size of 3 tooth pics put together I did it all for about 25 cents.
