Saleen Supercharger Series II
Hey gang, found this on ebay. I would def look into getting this if it is worth it. What do i need to complete this/what is necessary for installation? How much would i gain from this? Saleen Charger
RE: Saleen Supercharger Series II
series II is a eaton m-90 roots blower, its intercooled and not a bad setup for the street. Looks like a complete unit, make sure all hoses and fittings are included or else you will go crazy finding the correct parts. If it sells cheap its worth it though.
Here you go read this,
http://www.corral.net/forums/showthread.php?t=629507
I dont see anything in the austion that says it comes with a heat exchanger which is something you will defintely need. However you can pick one up from Kenne Bell of wherever this guy got his. From the looks of it, the series II doesnt make to much power unless you have alot of bolt ons and such. But if you do buy it, that post could be your guide. The guys at www.chicanesport.com could also help you out, give them a call. Good Luck.
I almost bought one of those. But after doing research I realized you will eventually just hit a wall with that blower. I would look around for a used vortech or procharger imo.
