Questions about differnet Fuel
RE: Questions about differnet Fuel
ORIGINAL: aMerICAn_mUsCLe79
if ur stock its not.....ur car will acctuly run crappyer if u use higher octane on the stock stang
I see a lot of people saying it's a waste or it hurts your car, but can anyone actually explain why? I've wondered about this too and I'd like to hear from someone who has a explanation from theory. It looks obvious to me that the higher quality the fuel, the better it is for your car but my ears are open to the truth.
Higher octane simple resists pre-ignition... it burns all the same once ignition has begun. Octane rating has nothing to do with quality... like I said, simply, octane = resistance to pre-ignition.
Edit: Corrected typo. And, here, to dispel myths further... because some people just remain ignorant.
Explains why unleaded fuels are never above 100 octane, and why fuels above 100 octane are leaded only.
The name "octane" comes from the following fact: When you take crude oil and "crack" it in a refinery, you end up getting hydrocarbon chains of different lengths. These different chain lengths can then be separated from each other and blended to form different fuels. For example, you may have heard of methane, propane and butane. All three of them are hydrocarbons. Methane has just a single carbon atom. Propane has three carbon atoms chained together. Butane has four carbon atoms chained together. Pentane has five, hexane has six, heptane has seven and octane has eight carbons chained together.
It turns out that heptane handles compression very poorly. Compress it just a little and it ignites spontaneously. Octane handles compression very well -- you can compress it a lot and nothing happens. Eighty-seven-octane gasoline is gasoline that contains 87-percent octane and 13-percent heptane (or some other combination of fuels that has the same performance of the 87/13 combination of octane/heptane). It spontaneously ignites at a given compression level, and can only be used in engines that do not exceed that compression ratio.
During WWI, it was discovered that you can add a chemical called tetraethyl lead (TEL) to gasoline and significantly improve its octane rating above the octane/heptane combination. Cheaper grades of gasoline could be made usable by adding TEL. This led to the widespread use of "ethyl" or "leaded" gasoline. Unfortunately, the side effects of adding lead to gasoline are:
Lead clogs a catalytic converter and renders it inoperable within minutes.
The Earth became covered in a thin layer of lead, and lead is toxic to many living things (including humans).
ORIGINAL: mustang gtizzle
So, what is octane? Simply put, octane is a measure of gasoline's ability to resist ignition under compression. That spontaneous ignition is often referred to as "pinging" or "knocking", and those words describe well what it will sound like. The higher the octane, the more compressed the fuel can be before detonation/knocking.
However, this is not all that octane is. Going further in-depth, we come to see that octane is more than a rating, it's a hydrocarbon. Like other hydrocarbons (methane, propane, butane, and heptane), its chemical composition includes carbon atoms. The exact composition of octane consists of eight carbon atoms and eighteen hydrogen atoms, scientifically written out as C8H18. A fuel with a 100 octane (100% octane) resists detonation/knocking extremely well. Because of that, all fuels are compared to the 100% octane bench mark, and thus, an octane rating can be obtained. Transversely, heptane, another hydrocarbon, resists detonation very poorly and will spontaneously combust under even the smallest amounts of compression. This poor ability to resist combustion under compression gives heptane an octane rating of zero, and thus, makes heptane the other bench mark for determining a fuels octane rating. For example, a fuel with 89% octane would have an octane rating of 89 and a fuel with a 11% heptane will also have an octane rating of 89. However, this does not mean that the 89 octane you use to fill up your 'Stang is composed of 89% octane and 11% heptane. It just simply means that a fuel composed of 89% octane detonates under the same compression as a fuel composed of 11% heptane under the same circumstances. And as if you weren't confused already, those octane numbers at the pump don't tell you exactly what octane of fuel you are putting into your gas tank. The octane labels at gas station pumps, monitored by the United States Cost of Living Council, are actually an average of two octane ratings. This is because fuels react differently under certain circumstances. The two main circumstances being used in an engine under free-running conditions, and being used in an engine under load. These two octane ratings are derived from the motor method rating, where the engine is tested under load-bearing conditions, and a research method rating, where the engine is free-running.
Now that we know what octane is, why is it that some describe a 92 octane fuel as being more beneficial or better than an 87 octane fuel? Often times, this is a misconception. There is no real benefit to running a 92 octane in an engine that is designed for, and to work with, an 87 octane. However, depending on the engine and its configuration, you may be required to run a 92 or even higher octane rated fuel. The higher octane fuel is required for engines running higher compressions, at higher temperatures, and with more advanced ignition timing. But does this mean you can't run a 92 octane in your engine with a recommended octane of 87? No, you can, but there really isn't any benefit to it unless you have advanced your timing or are running under forced induction (supercharger, turbocharger, etc.). In fact, all you are doing is wasting money. You won't experience any increases in horsepower or torque (unless you are already experiencing detonation/knocking), it doesn't burn cleaner, and it doesn't give you better fuel economy.
So, if higher octane gasoline doesn't really benefit anyone other than allowing engines that require higher octane to run correctly, why does it cost more at the pump? Answer to this is simple. The higher the octane, the more time and money it takes to process the gasoline to achieve that higher octane. These extra refining steps don't make the fuel any better though, which is what often leads most to believe that it is better for your car to run a higher octane than needed. All that the refining companies are doing is creating a gasoline that will allow those who have cars with engines that require the higher octane to run correctly, and that is why it costs more.
We've come to the conclusion that 100 octane means that the fuel can resist spontaneous combustion extremely well, but how is it possible to have fuels with an octane rating of 100+? One method that is done in the refineries to create race and airplane fuels is to include certain additives such as tetraethyl lead that increase the engine's ability to operate under higher compressions without detonating. However, some companies have begun developing items known as "Octane Boosters" that increase the octane rating of your gasoline. These octane boosters can be purchased for relatively little money from automotive parts stores and the gas stations themselves. The only major drawback to these octane boosters is that the higher octane you are already running from the pump (such as a 92 or 93 octane), the less of an octance increase you will see.
At this point, I hope you've come to realize that you don't need or want to run a higher octane fuel than is needed. The myths about what octane is and what it does have been put to rest and the scientific truth has been shown.
I didn't want to make my own thread for this so I thought I'd post here. I misplaced my owner's manual for my 2002 GT and I am forgetting what grade octane it says is required. 87? 89? If someone knows that would be great.
ORIGINAL: SikGT
Is it wasting money, or wasting gas?
I took this pic today this afternoon. This is just Bull$#!t!
