what should i expect?
2000 mustang gt , 5 speed......4.10 gears, bbk longtube headers, bbk o/r x pipe, bbk 75mm tb, accufab 75mm plenum, jlt ram air cai, steeda udp's, steeda tri ax shifter....kumho tires.....what kind of time should i see tomorrow when i go to the drag strip?
RE: what should i expect?
Dude. Thats a lot like that i have man. I just also have U&L CA and weld in subframes and eibach suspension a diablo tuner and all that. You should be running high 13's if you can hook up.
man i ran 13.6 without cai, udp's and headers were leaking real bad at the manifolds....and my x pipe was unbolted from the catback.....the track is bout 3 hours from my house and on the drive up the flanges on the x pipe pulled away from the catback...im lookin for a 13.0-13.3
Expect mid to low 13s on drag radials with a decent (1.9 or lower) 60' time, assuming that the tune in your SCT is working with your modifications.
Not sure where they are getting high 13s/low 14s from, the car should run a 14.00/14.2 stock.
treesloth
09-28-2015 07:03 AM
