5.4 swap
#62
RE: 5.4 swap
The headers ain't gunna be cheap from the first guys... the company is known for quality you pay for.
The intakes are booking at 795 last I got back from HPS. I asked for a GP but he didn't reply to that request so I'm taking that as a no right now. The intake is cast aluminum and fits under stock 99-04 gt hoods. I'll bet $1 that it'll fit under a stock 96-98 hood too.
#64
RE: 5.4 swap
amoosenamedhank....
what kind of exhaust do you have??? you said you tried the long tubes but they didn't work...and you dont have shorties....so what do you have...stockers??
edit:
NM! just read back and found out you made you own....
hm...now what am i gonna do?? [&:]
edit:
#65
RE: 5.4 swap
ORIGINAL: whitestang97
amoosenamedhank....
edit:
amoosenamedhank....
edit:
#66
RE: 5.4 swap
yea...think i might try and moddify my longtubes and see what happens....
i have a 5.4L short block...no water pump, starter, alternator, ac, ps pump,nothing....with everything from my 4.6 bolt right up to the 5.4??
#67
RE: 5.4 swap
#68
RE: 5.4 swap
It depends on what intake you use. Here's what I had to change when I swapped to my 5.4 intake setup. The fuel lines are on the other side of the rail so I had to change that. The alternator is different so you'll have to buy a new one of those. The rest of the accessories work but I had to buy 1 new tensioner because the timing cover was different. That's all I can remember now, I started this a long time ago I like to drink, which makes me forget things.[&:]
This is all assuming you are doing a 2v. Oh and fyi when I made my headers I didn't just modify the 4.6 headers. I cut the headers 6" from the flange, bought a header fab kit and started cutting and my friends was welding.
#70
I am going the 4v route using '03 heads. I got two boss 290 intakes coming from AU; got them off ebay au. I plan on using whatever the cheapest low mile engine I can get and going through ford for the timing chains (Shelby GT500). I don't know what to do for cams. I have aviator heads with cams, all the info I can get say they are the same as Mach 1. I am thinking about the fr500 cam kit, but the cost, and I think I can have a custom grind for the setup for the same price.
