Finally a 13
Finally a 13
Many know I have been trying to get my '99 GT Convertible with an automatic to get the passport timer to read a 13. I started with a best stock of 14.42. First added 4.10's and a predator tune that did not really add much at all due to the rest being stock. I did add a set of bullitt wheels, 17"x9" & 10.5" with 275/40's and 315/35's for looks and traction with the 4.10's. Next was a PYPES catted x-pipe and catback that gave about a tenth. I deceided to change the plugs and put in NGK platinums and surprisingly these turned out to be the best mod to that point netting a 14.17! Of course temps and weather conditions changed over the course of these mods. Then I went with a JLT CAI which dropped the time to a 14.02 and added .9 mph. So close but still not there. Then I learned of a timing adjuster made by Steeda. I found one in the classifieds and made the purchase and deceided to do the UDP's at the same time. Made the changes and added 7* to set the base timing at 17*. Still no 13. After consulting Brent at Brenspeed I took out the 10% I had added to the tune above 4k, timing wise. Nope. Then another 20% was removed above 4k rpm and a 13.95 was netted at 100.7mph. 0-60 was lowered from the previous best of 5.55 to a 5.42. Not bad for a NA 281 c.i. motor in a 3350lb. car with an automatic. I still can change the TB/plenum and after I sell the Predator I will get an SCT with a custom tune from Brenspeed and possibly hit a 13.75, that would be nice. Thanks to all, Mark
RE: Finally a 13
There is more to be had for sure. I cannot launch with any type of power launch as it would fry the 315's. I just turn off the traaction control and punch it and get about a 3' spin and it hooks and go's with 60' in the 2.15 range. Not really looking for a track time but looking for more engine power for street action. I plan to enjoy the next couple of months driving it before it's storage for winter. I just got the car in the spring and it's a great car, runs like a top and being a drop top a lot of fun. Just 56k miles on a '99 so plenty left. mark
RE: Finally a 13
ORIGINAL: JonBeastAre you actually running at a track? You said a passport timer?
On a personal note I have had 3 back surgeries and after breaking my back the second surgery, where they went in through the back and front, they used cadaver bones and a few screws to hold me together. A Morphine pump was added back in '03 and is maxed out feeding my spine the drug 24/7. I have Methadone and Dilaudid along with Valium and a couple of other lesser known drugs keeping me going. I would have a difficult time driving the 45+ minutes each way to the closest track and they don't run test and tune for street cars very often.
Now back to the timer. It's 100% accurate for speed, within hundredth's. Just using it as some guide I have taken off .5 and added 4.7 mph to what it reads. I also use a passport radar detector, that works well also. I know I can't convince anyone that my testing is accurate for what I am trying to accomplish. Sorry. As in some other threads it is not 1/4 mile that I am interested in. Don't get to the track very often, '79 was the last time I raced. Although I don't condone street racing if anyone thinks their car is around 14 flat and is able to drive to Auburn, NY I will line up with you. By the way Jon you had the timing adjuster set on 16* with stock being 10*. It still works well with 93 octane though, no knock. Great mod and only n$139. new I highlly recommend it but take away timing up top as motors don't like a lot of timing at highr rpm's. mark
RE: Finally a 13
ORIGINAL: 4.698GT
Yea, what is a passport Timer
RE: Finally a 13
ORIGINAL: Matts00GTThen all you have to do is go to a REAL track and get REAL times.
