Best Shift Points
RE: Best Shift Points
you dont want to shift right when you loose the power in your dyno chart because then you will just be low in the rpm range when you get in the next gear. You need to go a little more than where your power stops so then when you shift your rpms will be a little higher to begin with.
ORIGINAL: MustangChris04
jwog666
12-27-2021 08:09 PM
